cub cadet 2166 won't start
   / cub cadet 2166 won't start #1
ttb
asheboro,nc
cub cadet 2166
I have pulled engine,change spark plug gap .30, checked fuel lines cleaned carburator, changed battery. Anyone know what else i can do? Thanks
   / cub cadet 2166 won't start #2
1. Do you have spark across the plug gap?
2. There are numerous safety interlocks which if not functioning correctly can keep the ignition from receiving voltage. On mine, there was a switch connected to the brake pedal which wasn't making connection.
jack vines
   / cub cadet 2166 won't start #3
OP - first determine what is the problem. Start by having assistant crank engine normally ( clutch/brake fully depressed, PTO switch off, Choke off, throttle 1/2) while youy spray several shots or rattlecan carb cleaner directly into open carb throat (air cleaner removed) - if engine "pops" or tries to run, problem is fuel delivery. If not, problem is ignition or mechanical.
Ignition - Purchase ignition spark tester from briggs shop so that you can chk for spark with plug IN ENGINE and UNDER COMPRESSION. Will msave you a ton of diagnosis time and inexpensive. If ignition OK, remove flywheel and verify flywheel key not partially or fully sheared. Consult engine service manual for procedure (a must).
If no ignition at all, then time to trace OPR's (CL/BR sw, Seat SW, etc.) for proper function. Crank but no start is most often associated with defecvtive seat switches and on most models, you cannot simply "jump" them out of the circuit. :(
Mechanical - pull valve covers, chk for loose rockers/rods/etc. cranke engine over by hand and observe lifter movements for consistency.
fuel delivery - remove fuel hose at carb - crank engine - catch fuel - should be a good amount/flow. If not, trace back for problem, repair/replace including fuel pump, fuel filter, flexible fuel lines back to tank. Also chk vacuum relief at fuel tank cap. Make sure only OEM fuel filter for engine make/model is installed - no aftermarket.
If fuel flow OK at carb, pull/disasm carb. soak in carb cleaner overnite. Using small dia stiff brass wire and MAGNIFYING GLASS, probe ALL component orifices and blow out same with clean compressed air. reasm carb using new rebuild kit and all new gaskets/seats. Retest on engine.
good luck.
2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
2022 JLG R3246...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2019 FREIGHTLINER...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
