Cub Cadet 2186 Engine Won't turn over
   / Cub Cadet 2186 Engine Won't turn over #1
Jaquette0418
Cub Cadet 2186
Battery is fully charged with good cranking amps. Appears that one of the saftey switches is malfunctioning. Turn key and only get a clicking noise. Where do I start as far as checking out the saftey swithes.
   / Cub Cadet 2186 Engine Won't turn over #2
To verify it's one of the switches jumper the large terminal to the small terminal on the starter solenoid with a old screwdriver or a remote starting switch, if it turns over that way you know the starter is good.
If the starter is good then likely you're losing voltage somewhere in the safety circuit. This a common problem and ther a fix where you add a relay in the starting circuit. http://www.tractorbynet.com/forums/...arter-problem-again-cubcadetstarterwiring.pdf
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
