Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve?
   / Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve? #1
Joelk
PA
Cub Cadet 3165(for Parts) 3100, 3206, 3240, 3200 with Snowblower, 5252 with FEL and 60" MMM
I have several 3000 Series Tractors and one of them recently had the PTO Vacuum Solenoid go bad,
I swapped one from another tractor to confirm that the valve was bad.
New from CC they cost about $80 and I will probably need more than one as I plan to keep using 3000 Series for a long time.
I am hoping to find a substitute that is less expensive. I did a bunch of searching on Amazon/Ebay and found many that look like they will work, with some fabrication.
I bought one and it should work, but I will need to make modifications to the wiring to use it.
The CC OEM valve appears to have a GM style Weatherpack Connector.
Has anyone found an inexpensive valve that will work with very little, or no modification?
If so, please provide link/photos/part#s
Thanks, Joel
   / Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve? #2
Thank goodness an l60 commercial Tank replaced the 3235 I had but I think if you take that soiinoid to a napa there is a GM solinoid that matches it. Been six years since I I had it and Ive slept since then!!
I am still looking for a low cost alternative to the OEM part. Any suggestions?
   / Cub Cadet 3000 Series, Substitute PTO Solenoid/Valve? #4
Well for starters, you could give us the Cub P/N and perhaps post a photo of the old one.
Richard
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A50046)
2013 INTERNATIONAL...
2015 VOLVO TRUCK VN SERIES (A48992)
2015 VOLVO TRUCK...
Cummins Onan Commercial QD Generator (A49251)
Cummins Onan...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
Agrotk 72" Skid Steer Broom, New  (A47371)
Agrotk 72" Skid...
2014 FREIGHTLINER CASCADIA DAYCAB (INOPERABLE) (A48992)
2014 FREIGHTLINER...
