Cub Cadet 3225 Hydraulic Trouble
   / Cub Cadet 3225 Hydraulic Trouble #1
kreiderc
I have a Cub Cadet 3225 that first had the mower deck hydraulic lift quit working. Then the hydrostatic transmission quit working at full speed. Then the power steering quit working. Where might our problem be? The fluid is full & clear. Is it the main pump or the valve on the side next to the transmission? I'm at a loss. :mad::confused: I see on the parts list that is also has a pump at the base of the steering column. Any ideas on where to look first?
   / Cub Cadet 3225 Hydraulic Trouble #2
Change your hydro filter. A clogged or dented filter will restrict flow and cause all of the problems you described. First and cheapest place to start.
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
MANTIS 155B LOT NUMBER 230 (A53084)
MANTIS 155B LOT...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
