dumbfarmboy
Convinced a friend that this was a better deal than a 22hp Mitsu with loader for $5900. Got this for $2600. Has 485 loader, motor turns over, doesn't start. Burned out glow plugs, relay and controller which seems to be a common failure. Has electrical issues as key won't crank it. Got the fenders and decking off and pressure washed today. Hopefully we get some of this ironed out tomorrow. After doing some searching I found a service manual for the Mitsubishi SL engines and the specs for the glow plugs indicates 10.5V but the ones installed are 8V (NGK Y-724U). I found a chart of NGK GPs with dimensions but that p/n isn't on it. I also found a site where another 7360 owner used Y-107V and comparing dimensions with the old ones I pulled out, that p/n is the correct size. Plans are to replace the existing control with a momentary switch that will control a 40A relay to lite up the GPs. I also found a service manual, seems to have good info for everything except the electrical component layout. Oh well, at least it has a wiring diagram.
