Cub Cadet lt1045 now only cranks, ran fine for 7yrs now nothing
   / Cub Cadet lt1045 now only cranks, ran fine for 7yrs now nothing #1
buzz999999
middleburg heights
lt1045
My lt1045 will not start. After trying to start it and it spit just a little while in choke it now doesnt even spit. I checked gas, replaced plug, replaced oil, replaced, fuel filter, fuel pump, fuel solenoid. It has spark and ive tried ether and that will let it spit but not much. I checked seat safety and have tried running with it disconnected....I am stumped...can anyone offer a suggestion?
   / Cub Cadet lt1045 now only cranks, ran fine for 7yrs now nothing #2
You say it has spark, but I'm not convinced.
Changing oil, filters,etc on a rig that won't start is hunting.
Squirt fuel down the intake (I assume it's gas if you mention spark) crank without choke and wide open throttle until it starts or clears (should be flooded)
I would check your ignition wiring...
Good luck, I've been here many times
   / Cub Cadet lt1045 now only cranks, ran fine for 7yrs now nothing #3
What type of engine does it have and how old is the engine? BTW, welcome to TBN. You might want to move this question to the Cub Cadet and LAwn and Garden forums.
Full throttle and no choke till it clears...Ill do that. Ive tried that but will try again. I saw on another thread that pin could be sheared on flywheel to offset timing....ill check that...If that doesn't work what is the best way to check ignition wiring, it looks good but i know looks can be deceiving.
Its a 20hp Kohler Courage engine. About 7 years old with about 150 hours on it.
   / Cub Cadet lt1045 now only cranks, ran fine for 7yrs now nothing #6
No spark or weak spark since it slightly sputtered using starting fluid, I'd suggest looking at your magneto timing. I had a riding mower my son left outside and it quit running. Wouldn't hit a lick. I checked out the ignition circuit and the magneto had rusted up thus changing the air gap which is about the thickness of a piece of paper. Sanded down the pieces to clean off any rust and it fired right up.
Thank you...I found the problem, it was a sheared keyway in the flywheel... apparently due to a recall where there was not enough torque put on flywheel bolt...in fact the bolt just spun off with my fingers. Apparently i am getting air in my system because its reving at low rpm and I was told that is due to air. I think i might have assemble the fuel solenoid to loosely.
   / Cub Cadet lt1045 now only cranks, ran fine for 7yrs now nothing #8
Welcome to TBN :)
I moved your thread to the Cub Cadet L&G forum.
2008 Ford F-350 Flatbed Truck, VIN # 1FDWX36R18EE18011 (A44391)
2008 Ford F-350...
2004 TRAILMOBILE 32FT DRY VAN (A43004)
2004 TRAILMOBILE...
2017 WK MACHINE 32FT + 4'  ROLLERBED HYD TILT W/ CRANE TRAILER (A43004)
2017 WK MACHINE...
2014 Royal Enfield Continental GT Motorcycle, VIN # ME3FSV293EK600951 (A44391)
2014 Royal Enfield...
2004 Ford Expedition XLT 4x4 SUV (A44572)
2004 Ford...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
