CUB CADET LT1050 Charging problem with blow fuse.
   / CUB CADET LT1050 Charging problem with blow fuse. #1
SmallEngineGURU63
Ladysmith, Wi
CUB Cadet LT1050
I have a 2007 Cub Cadet LT 1050. I suspected there was a problem with the charging circuit when it popped the fuse. I un-plugged the wire harness going to the Stator and was able to turn the key on and could crank the starter. When I plug in wire from the Stator charging circuit and try to start it it pops the 20amp fuse. I evidently have a failure a short in the wiring or bad stator or voltage retifier. If anyone has experienced the same trouble and has corrected the problem I would like some input Thank You.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
71065 (A49346)
71065 (A49346)
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
