Cub cadet model 2155
   / Cub cadet model 2155 #1
Dustyg
Tractor has a Kohler model CH15S engine with 875 hours. Engine is running , but It’s burning a lot of oil with blue smoke. Compression is 65psi cold and jumps to 75 psi when I put some oil in the piston housing. What is the normal average for compression for this age of engine and could it be the valves ? Thanks in advance for any advise Dustyg njmorleyg@gmail.com
   / Cub cadet model 2155 #2
Welcome. Maybe a failing head gasket?
   / Cub cadet model 2155 #3
If the pressure changes when you add oil your rings are probably shot.
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
