cub Lt 1042 clutch wires
   / cub Lt 1042 clutch wires #1
bamaman01
Section Al
cub LT1042
Does anyone know the gauge wire to wire up the clutch? Got a broke one.
   / cub Lt 1042 clutch wires #2
typical elect PTO draws around 4-6 amps - would think 12-14 ga wire should be enuff....
   / cub Lt 1042 clutch wires #3
usually when you pull of the deck,sometime's you need to BACKOFF ,the belt guard to remove the belt if you completely removed the guard but did not install it so the guard goes in the clutch slot the clutch will spin and pull out the wires,if you are lucky you can resolder the wire to make work .12-14 ga should be fine if you need to ad wire
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
Land Honor Quick Attach Rock Bucket (A50514)
Land Honor Quick...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2015 CATERPILLAR D6T XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
