Cultipacker Wheel and Shaft "Bearing" questions
   / Cultipacker Wheel and Shaft "Bearing" questions #1
160classbuck
Valders, WI
Leyland 254
Well I have watched topics on TBN but this is my first post.
I have a 10' cultipacker with no manufacturer ID on it that is in need of some repairs. The wheels measure approximately 11.5" and are of split design. Some of the wheels have cracks in them and some have pieces completely broken away. I have managed to remove the end plates, clamp on collars and all the wheels. I know I could just remove the bad wheels and slide the collar clamps in further and go but prefer to replace what I can with as close to original parts as possible.
The help I need is:
1. Where to buy / find replacement split rollers
2. For the split rollers I have, some are riveted together, some appear welded and others are come apart. Does this matter?
3. The end of the shaft fit into what I will call a cup bearing that appears to have a soft metal (maybe lead) in it that is being worn away, how do I repair / replace that?
4. Any idea on who manufactured the packer?
Here are pictures of what I have.
Thank you for any replies.
IMG_2523r.jpgIMG_2524r.jpgIMG_2525r.jpgIMG_2527r.jpgIMG_2528r.jpgIMG_2529r.jpgIMG_2530r.jpgIMG_2531r.jpg
   / Cultipacker Wheel and Shaft "Bearing" questions #2
That looks to be Babbitt bearings. Guessing it'd be easier to remove, and replace with a bronze bushing/bearing.
For the cracked ones, if you have a DC reverse stick welder, and some Nickle rod, you could probably repair them.
For the broken one's, searching for 9.5" cultipacker wheels got many, many hits.
Thanks DJ54 for the reply.
I like the idea of the bronze bushing replacing the Babbitt vs. repouring. I have a wire welder but will have to search out some friends with stick.
Thanks,
Dave
   / Cultipacker Wheel and Shaft "Bearing" questions #4
Lots of old culdipackers used oak & grease for bearings. They only lasted a few decades of hard use...
The shaft doesn't turn that much as the wheels mostly turn on the shaft due to the massive clearances between shaft & wheel. That space let's each individual float a bit to get maximum ground contact when it's not level.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2019 Dodge Durango AWD SUV (A53424)
2019 Dodge Durango...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
1984 Gleaner A630 Corn Head (Deutz-Allis branded) (A57024)
1984 Gleaner A630...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
