Cultivators for Farmall Super A
   / Cultivators for Farmall Super A #1
North Georgia
Lula, Ga
Kubota9000 Farmall Cub
Can anyone tell me if cultivators for a Farmall A wil fit on a Farmall Super A?Thanks
   / Cultivators for Farmall Super A #2
In sure that the hookups are pretty close, except I'm sure you know that the Super A is hydraulically operated and the A was a manual lever that raised/lowered the cults. If you wanted to use the manual lever you need to find out if the lever connections/pivot points were left on the SA. sorry for not knowing "for sure", but don't know of anyone that still wanted to man-handle the cults versus using the hyd. lift. BobG in VA
   / Cultivators for Farmall Super A #3
I believe you will have to modify the cultivator from the A to work on the Super A. I am currently trying to put a set of cultivators on my A and am having great difficulty figuring out the proper set up. I apologize for going off tract here but do you or anyone else have any good photos or pictorials for the proper set up . This may answer your question as well.
   / Cultivators for Farmall Super A #5
Thanks for the photos but unfortunately they are for a Super A and it shows the use of the hydraulic lift. I am searching for photos of a manual lift cultivator attachment. I must admit I never imagined this would be such a difficult quest. Thank you for your photos just the same. I may just get a set for my Super A and use the A for towing a cart.
   / Cultivators for Farmall Super A #6
There is a book you can get at books a million that covers the restoration on international/ farmall tractors, there are some good pictures if the Farmall A's in there with cultivators. I don't remember the name of the book
   / Cultivators for Farmall Super A #7
I'd post this over at YTMag or the redpower forum. Both have forums specifically devoted to farmalls.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Freighliner Tender Truck (A53473)
Freighliner Tender...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2016 PETERBILT 389 (INOPERABLE) (A53843)
2016 PETERBILT 389...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
