Cummings Engine Problem
   / Cummings Engine Problem #1
meledward23
too close to Graceland....
1025R
I have a 96 Dodge One Ton with a 5.9 Turboe Diesel. It has been stalling out in idle for a while and now only starts at random times. The fuel pump and fuel filter have both been replaced.
Any ideas on what might be the problem? Once the truck has the fuel pedal depressed it runs fine. Stop at a traffic light and it may or may not stall. The worst instance is when you put it in reverse. Stalls out 50% of the time.
   / Cummings Engine Problem #2
It could possibly be dirty fuel injectors. Mine (also a '96) acted something like that before I put in larger injectors. When I pulled out the original injectors, they were pretty dirty. Now, you can't turn the key to start without it immediately starting. All it takes is the slightest bump on the starter and it starts and runs fine.
   / Cummings Engine Problem #4
Might be the fuel return or supply line. They can become brittle and leak, allowing the fuel system to loose prime.
Dave
   / Cummings Engine Problem #5
It's those darn Cummings engines, a Cummins runs much better. /forums/images/graemlins/grin.gif
Seriously, go Here for some good info.
Forget it. Off to the Evil dealer with this truck again. Of course this is the first time it is for an engine problem and considering the way my wife takes care of her truck it is probably maintenance related.
AND I am ignoring the comment about my spelling. /forums/images/graemlins/cool.gif
   / Cummings Engine Problem #8
my Dad use to have a 97' that did the same thing,and somebody told him that they had a problem with the throttle cable stretching in turn not holding it where it should and idling to low,I thought he said something about a recall on it but I'm not sure,you might want to have it checked just in case,could be a cheap fix for your problem.
   / Cummings Engine Problem #10
There was a recall on the throttle linkage.
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
