clovergamecock
Good Morning all!
A lot of you know I had a house moved off my land and left with a mess of tree's and brick. The brick I have found uses for. The trees I might have a use for. I probably have enough of the same size diameter as a store bought 8' corner post to make plenty of corner and line "H" structures in between the tPosts for tghtening the solid wire. Most of these are pine with some hardwood. I need to expand my pasture fencing and was thinking of cutting the trees to length and using them to build my "H" corners and lines.
Can I do this?
Will they hold up to the strain of the ratchet tighteners?
If I can use them I am sure I would need to coat them with something? What would it be and where can I get it?
Wade
Can I do this?
Wade
