Cutter top plate life
   / Cutter top plate life #1
Jw5875
NW Pa.
Kubota L3400
New education on sharpening chains for me, trying to keep chains up to par, found out that when the top plate reach 50% of length, time to replace the chain and don't waste your time trying to sharpen it, setting depth gauges etc.
At 50%, it does not have the side or top clearance specs no more.
JW 5875
   / Cutter top plate life #2
Sounds like an educator wanting to sell you new chains.
   / Cutter top plate life #3
Agree with Lurch. I use chains right down to the nubbins, to where most are marked or a bit more. At about half or a bit further along I do drop a file size, if I have one. Not sure that is even necessary. I will typically wear out three chains like that using them in rotation and then get three more with new cog rim.
prs
   / Cutter top plate life #4
Wow somebody wanting to sell chain it looks like. IMO some of the best chain cutting is 50% and further. You just got to adjust your raker down as the tooth goes back. No problem.
I sharpen guys chains till I dont have a tooth left.
Race chain making starts when cutter back near the rear rivet too. ;)
   / Cutter top plate life #5
JW 5875
Don't forget to get the air changed in your tires every other year. Sorry, but either one would be about the same as to wasting $$$$$. Someone saw you coming and figured you had to much money and thought you should give him some. Ed
   / Cutter top plate life #6
JW 5875
Saw chains used in racing are ground all the way down to the wear limit to increase clearance for chips. I assure you a chain is good to that point, provided it's been sharpened properly.
   / Cutter top plate life #7
Don't they usually come marked with the tooth angle/last limit of use right on them? I think the raker interference is all you have to get down past.
   / Cutter top plate life #8
I cut them down to they are almost gone. Take the rakers way down too.
   / Cutter top plate life #9
Angle yes, last limit, nope. I used to log and trust me I have spent time with saws but this is a new one to me. Ed
   / Cutter top plate life #10
This is funny, at 50% they are just getting better. :D
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
