CV Joint Maximum Operating Angle?
   / CV Joint Maximum Operating Angle? #1
Rgillard
Ireland
Fiat 82-94
Hi Guys,
I know this is kinda off the point but I know some of you will have the answer. On my off road buggy I am using driveshafts off a nissan sunny '87 1.3L. I am just wondering what is the maximum angle I can run these shafts at before damaging them. I want to try and get as much road clearance as possible without doing harm. Thanks to anyone who can help.
Regards,
Ronan
   / CV Joint Maximum Operating Angle? #2
not much
i know on my 4wheel drive 94 pickup (set up for offroad) with balljoint spacers im pushing 25-30deg and thats about the limit.
usually the joints can go farther than the boots. so youll tear the boots. but if your looking at a compound angle (turning and flexing) is the hardest on the joint and will likely snap quickly.
I assume those are the same birfield design the pickups use.
   / CV Joint Maximum Operating Angle? #3
Try asking on one of the Pirate 4x4 forums. If someone there can't answer your question nobody can.
http://www.pirate4x4.com
   / CV Joint Maximum Operating Angle? #5
Click on Bulletin Board to go to the forums.
   / CV Joint Maximum Operating Angle? #6
WOOOO WOOOO WOOO....
you do NOT send a noob into Pirate. He'll get chewed up and spit out for shure!
You got to watch it over when i say there they are rough, thats an understatment!
   / CV Joint Maximum Operating Angle? #7
Yeah, I visit Jeep sites a lot. That one is brutal. They expect you to know everything. If you knew everything you certainly wouldn't be asking a stranger questions on a website forum!!!!
I think you should keep your CV joints at or below 20 degrees if you expect long life. But then there's nothing in 4 wheeling that has a long life. Regular joints can't survive much past 15 degrees for any amount of time.
   / CV Joint Maximum Operating Angle? #9
All of my information says that 18* is max for the inner joint and 45* max for the outer. Dont forget that you need to allow for wheel travel, so you wouldnt want 45* sitting on the ground.
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
