cyl mounting angles
   / cyl mounting angles #1
northernguy
I want to make my rear blade tilt and angle hydraulicly.What would be the proper mounting angle of the cylinders to put the least amount of force on them when draging the blade.I'm thinking of using either a 6" or 8" stroke cly.
Should the moving mount be closer or farther from the blades pivot point.
   / cyl mounting angles #2
northernguy, the farther you mount the cylinder end from the blade pivot the less force on the cylinder, but the longer the stroke on the cylinder has to be. You did not say how big of a blade you are working with, I used a 2" dia X 8" stroke on my 60" blade it is mounted about 8" from the blade pivot, I have no problems with the cylinder. Your distance from the blade pivot will be determined by the cylinder stroke and how far you want your blade to pivot.
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
