D2350 problems
   / D2350 problems #1
wayne2342
Western NC
My neighbor has a D2350 that seems to produce black smoak too much. Also it appears to be running off 3 of the 4 cylinders plus when the tractor idles for very long the oil level appears to rise slightly. When the tractor has run for some time, the motor will surge which may be the 4th cylinder firing for a minute. All of these issues may be related, eg smoking due to unburned fuel, fuel leaking into the crankcase through dead cylinder. The injector for the dead cylinder was pulled, cleaned and tested at a local shop and is has a good spray pattern. Anybody have any advice on what could be causing these problems?
   / D2350 problems #2
Broken or stock rings.
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
