yooper jim
D600 sat for many years (one outside). It is a 1800 RPM (I think) engine out of a reefer. Engine would turn over easily with wrench on crank. When I drained the oil, it had several cups of clear water in it. I assume rain water, because stack is pointed up and had a plastic bag stuck in it. Engine had anti freeze in it and was full, so it didn't come from there (I assume). Pulled glow plugs added some oil to each cylinder and cranked it over for a while. Did this several times. While they were out, I hooked up the three glow plugs and the all turned red when energized. It was very very hard to start the first time. Smoked white like heck at start up, but ran rather well. Ran for 15 min.
Changed oil and filter again, while hot. No water. Started again and ran for awhile. Steam and water came out of the breather tube off the valve cover. After it warmed up well this stopped (residual rain water?)
Checked compression and all were in range. Front cylinder was 385 PSI and the other two were both 425 PSI. 385 is within 10% of the other two. So I assume it is ok. Hard to start as usual. While running I cracked each injector line and each made a difference.
Very hard to start even at 50F with glow plugs. 30 sec (at least) of cranking and it stumbles along like it is flooded and belches white smoke. When it catches it runs ok with no smoke. Have to use glow plugs to restart even when warm. Doesn't seem to have the power it should. Anyone have any suggestions on what to check next?
Thank
Jim
Thank
Jim
