Davis D100A backhoe
   / Davis D100A backhoe #1
mmurphy
Platinum Member
I am trying to find some parts for the D100A backhoe.
Hoping someone may have some leads of anyone carrying parts for it. Thanks.
   / Davis D100A backhoe #2
Other than the dipper and boom and frame and bucket, most everything else (valves, pins, cylinders, etc.) are likely common. What do you need?
   / Davis D100A backhoe #3
What parts are you needing, I have the case version D100 and most parts are the same so you may check with the case ih dealer.
Case bought them out years ago.
Bottom bearing and possibly the pivot pin that rotates with the bottom boom. Top piece broke off, thought it maybe pressed in through a tube, but after getting bearing off, found it to appear it was one machined piece of metal. I am concerned about having it welded for you would have problem getting straight enough.
Thanks, will try Case IH dealer.
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
Skid steer Takeuchi tl15 (A59228)
Skid steer...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
