dearborn 10-152 plo shares
   / dearborn 10-152 plo shares #1
dinosaur60
portsmouth,ohio
1948 TE-20 ferguson
have scoured the web looking for plow shares for a ''Dearborn10-152'',2 bottom plow,,It is in good shape,,bought it for $100.00 ,the shares are worn,,any info as where a po boy might find them,will make them if have too,would rather find a set ,,Thanks ,,I am a new member with a 1948 TE-20 Ferguson,,,have owned it about a year now,,will be first garden plowed with it if I find the shares,,Thanks again,,any info would be appreciated,,Bill
   / dearborn 10-152 plo shares #2
if you have the old shares you can take them off and weld a piece of steel on the bottom in the shape of the share when it was new. i have welded truck spring to mine. if you get the right profile works just as good as a new one and also last longer.
   / dearborn 10-152 plo shares #3
Scroll down to Ford, then look at the 3rd item. angelinegroup.com/moldboard-plow.aspx
And I'm wondering if the bolt spacing is the same on 14's as 12's. Scroll down to see the first Ford Dearborn plow share 104410 (105203). Balster's Implement & Parts: Blade Shares
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
71069 (A49346)
71069 (A49346)
