Decent older commercial grade mower recommendations
   / Decent older commercial grade mower recommendations #1
Mikefromcny
Bronze Member
Upstate NY
White 2-65, Kubota B9200
Hi all, looking for a mower to replace her box store zero turn that's been anything but reliable.
Budget is around $3500. Could possibly do a little more. I've owned Lazer z's and thought they were a good mower.
I currently own a Kubota f2560. 2 seasons on it. It's been great. I'll let her use this while I run my 5' finish mower on the back of my Kubota tractor.
She'd like a zero turn, but would take a good out front mower.
Here's my understanding..
Exmark, Scag, Kubota - good mowers.
Toro groundsmaster..parts availability? Reliable?
Jacobsen turfcat - owned by Textron, expensive parts, and older ones are getting long in the tooth.
John Deere f series - old, parts availability?
She mows 2.5-3 acres once twice a week.
Diesel would be nice for longevity, and fuel consumption.
Not really looking for anything new but an older commercial grade mower.
I'm a diesel tech so not worried about repairs, just want something I dont have to work on every week.
Thoughts?
   / Decent older commercial grade mower recommendations #2
Charge up that flux capacitor and aim for 1990.
Personally Id consider moving if I had to mow 3 acres every week on a tight budget. Sell now while the property values are up and rent a small place instead.
   / Decent older commercial grade mower recommendations #3
I use a JD F-935: diesel, 2 tanks, aux hydraulic, cab available, blades are cheap even from my dealer, car battery.
All I've ever put in it is a battery, tire tubes, ignition switch and glow plugs. I pull a Woods leaf vac behind it without any strain. I also can hook up my PTO farm generator to the deck prop shaft and run the house off of it.
Parts manual on-line free. Lots of new and used parts for them on ebay. I often cut 10+ acres with it. Originally used to cut the fairways at a local golf course. They are all over the place here for under $3000.
WASTE OIL TANK (A50854)
WASTE OIL TANK...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
