LedgeMagnet
- Joined
- Jul 30, 2004
- Messages
- 18
I have 8 acres, mostly woods, mostly hilly and rocky, a small lawn (mostly gardens by now), and a small pasture with sheep, goats and a donkey in it.
I need something to gather firewood which would include light skidding of logs, move snow, repair a septic system (not a complete redo), move manure (out of a paddock and into a spreader, a smallish old ground-driven one), and turn more of my woods into pasture. I have no need to mow grass. My woods are pretty hilly, so things are tight, and stability is an issue.
I have looked at the 3054 and the CK30. I looked also at the DK35, but I am put off by the weakness in loader curl (unless they've fixed it).
Overall, the CK30 seems better to me, for the reasons you might expect, but I am wondering about the 3054XS TLB package:
1) How much stronger is the BH mounting on the TLB than on the regular 3054 or the CK30, which doesn't seem to have a TLB package yet?
2) Is the 1231 loader that comes with the 3054XS TLB (at least that is what the pictures show) enough stronger a rig to justify the cost?
3) How much ground clearance (if any?) do you give up with the different subframe setup in the TLB package? I won't often want the BH in the woods, and once it's off, I don't want a lot of steel hanging low.
4) Does all that steel around the 3ph on the TLB interfere with any 3ph implements, and do they give you the pieces to put the 3ph back in working order?
Does anyone have experience with this version of the 3054 or, failing that, care to hazard a guess on this stuff?
