Deck Material
   / Deck Material #1
tanglefoot
I want to replace our 2 X 6 cedar deck boards with a composite material so there won't be any need for periodic staining or sealing. I would like to find a tongue-and-groove board that will close the gap between deck boards so wasps can't go between them to build nests. Also, the 2 X 6's butt up to the concrete porches in several places, so the new material will have to match that thickness(1 1/2"). Does anybody have suggestions for the new top I'm looking for?
Butch
   / Deck Material #2
I have some pals who have used the composite deck material. It looks great but man is it ever slippery when it is wet or has snow on it. Test what you are going to get first as they really regret buying it.
Also, if you don't have any gaps how will your water drain off?
   / Deck Material #3
We tried to do the same, but found that the composite has significantly more "spring", hence required closer spaced joists than our 24'' centers. Ended up putting 2X6s back on...
Mike
   / Deck Material #4
I've got composite decking on 16" centers and I don't notice any spring in mine.
   / Deck Material #5
I used a solid vinyl deckboard that looks the same as 5/4 decking and is put down with stainless screws. not a all slippery and will never stain again:eek:. I looked at the composites that had hidden fastener systems and did not like the finish. you could always shim to get even with the concrete surfaces
regards
   / Deck Material #6
Mine is GeoDeck. It's an extruded composite material and has a texture of rough sawn material. Available in Cedar, Driftwood, and Mahogany colors too.
   / Deck Material #7
Where are you guys buying your material? big box stores?
I have kicked the idea around also. I have a small 12'x12' deck, but I have been given orders to add on 2 separate lower decks. I haven't pursued it far enough to price it yet.
   / Deck Material #8
Western - I bought my decking through a local supplier to the trades -- to get the colour I (SWMBO) wanted was a special order and the stuff I saw in the big box stores did not impress me
   / Deck Material #9
We put a porch on the back of the house a few years ago and went with the composite boards. We love it. One of the best decisions we've ever made.
I left a gap between the boards because it's required due to the expansion/contraction of the material.
If I was worried about bugs I'd lay screening down underneath it during the installation. Our porch is about 3 feet off the ground so I could get under there and staple screening now if I had to.
Just a thought.
-Len
   / Deck Material #10
Ipe (sustainable South American Tropical Hardwood) makes a very nice natural decking material - just predrill everything you do. Suppose to last 40 years or more (some say 100) unstained. Beautiful looking too.
Ken
2013 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A47001)
2013...
2025 KJ K1119 UNUSED Single Metal Carport (A47484)
2025 KJ K1119...
2015 Freightliner M2 106 Medium Duty Knapheide Service Truck (A44571)
2015 Freightliner...
2004 Caterpillar D6N LGP Tractor Crawler Dozer (A44571)
2004 Caterpillar...
2006 International 7600 DUMP TRUCK (A43005)
2006 International...
2025 Wolverine LHR-PC90H HD Plate Compactor (A47484)
2025 Wolverine...
