Deere 1050 - need hydraulic repair info
   / Deere 1050 - need hydraulic repair info #1
majorbacon
york, pa
1947 Ford 8N 6v positive ground system front mount distributor sn 10101 all OEM & Deere 1050 with front loader and back hoe.
My 1050 is experiencing hydraulic problems and I need some advice. Currently at a Deere repair center but they are having trouble sourcing original parts. If they cannot source oriiginal parts they will not use aftermarket parts. If it gets to that point I am bringing it home and then looking for someone local to work on it.
They mentioned the SCV valve needs replaced. Why would they not just rebiuld it? I see people online offering to rebiuld these valves.
I am venting a bit but in the end looking to see if anyone on this forum is familiar with this tractor and the hydraulics as I may need to ask some questions if the service center hits a dead end.
Thanks for listening an let me know if you have any advice to offer.
John S.
   / Deere 1050 - need hydraulic repair info #2
The JD 1050 was build from tires up by Yanmar if Japan to JD specs.
There is a Yanmar section on this forum. Use the Classics section for your questions.
Also if you get it back unrepaired, contact Hoyes Tractor for parts. Aaron is often on the Yanmar section if this forum and is a great resource as are others that are on that section of the forum.
Thanks for the info, I will follow your suggestions.
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
