Deere 5310 suddenly began intermittent registering hot
   / Deere 5310 suddenly began intermittent registering hot #1
Medicfields
Eupora
John Deere 5310
John Deere 5310 suddenly began intermittent registering hot. Changed the temperature sensor, thermostat.now will register hot on initial start....goes back to just over zero after a minute or so but, when it reaches just past halfway point, goes directly to maximum hot...Fuel gauge always reads full and did so prior to this issue.... looking for answers... suggestions.
   / Deere 5310 suddenly began intermittent registering hot #2
Re: Medicfields
I can't help with your problem, but you will increase your chances of getting useful responses if you change your thread title to include a description of your problem; e.g., John Deere 5310 registering hot.
To change the title, select "Edit Post" and then "Go Advanced."
Good luck.
Steve
   / Deere 5310 suddenly began intermittent registering hot #3
I would start by making sure you have a good ground, both at the negative battery terminal and where it connects to the frame. Disconnect it from the frame make sure the hole the bolt goes into, the bolt and the cable are clean.
On the fuel gauge disconnect the leads at the fuel tank. Put the key in the run position no need to start it. With the wires disconnect the gauge should read empty. Put the wires together and the gauge should read full. If this works as described the problem is in the fuel sender. If it does not work as described the problem is the wiring or in the cluster. With the negative cable disconnected you can pull the connector off the cluster and ohm test the fuel gauge wire. Lets hope it is not the cluster.
As float moves up or down with changes in fuel level, electrical resistance of potentiometer changes accordingly. When tank is full, resistance is low and gauge needle moves to full position. When tank is empty, resistance is high, and gauge needle moves to empty position. Potentiometer resistance between these two positions varies in direct proportion to changes in fuel level. This allows gauge to accurately display quantity of fuel in tank regardless of its level.
Cleaning up the negative terminal could solve the temp gauge. Do what was suggest for the fuel gauge, but this time test the temp sensor.
Temperature sender is a variable resistor that responds to changes in coolant temperature. Low coolant temperatures cause high resistance. High temperatures cause low resistance.
Thanks... I'll try the test on both... mostly concerned about the temperature
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
CAT CS563 (A47477)
CAT CS563 (A47477)
43029 (A51691)
43029 (A51691)
2018 Chevrolet Equinox AWD SUV (A55758)
2018 Chevrolet...
1991 BMY 6x6 Military Semi (A53314)
1991 BMY 6x6...
