Deere pto problems
   / Deere pto problems #1
Believer
On my 6210, the pto won't start. It has the lift and rotate actuator. I just replaced the speed sensor. Sometimes it will turn a couple seconds, sometimes not. Light on the console blinks. Any help would be appreciated.
   / Deere pto problems #2
My guess is the problem is with the PTO engagement valve. It's located to the right of the toplink bracket.
It is solinoid operated. It could be the solinoid or the spool of the valve is binding if the solinoid is OK.
It has two pressure test ports marked CLUTCH and BRAKE.
The system presssure should be 170psi at the BRAKE port with PTO disengaged. It should drop to zero when the PTO is engaged.
CLUTCH port should have zero pressure with PTO disengaged and 170psi with PTO engaged.
2023 John Deere S780 Combine (A53342)
2023 John Deere...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53472)
2023 NEW HOLLAND...
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT NUMBER 42 (A53084)
A1 MIST SPRAYERS...
