Def delete results
   / Def delete results #1
Rc4510
Bronze Member
Linden Alberta Canada
Ls xr4046 with cab
Has anyone that did dpf delete on older ls tractors have any results after long term.good or bad.I haven’t deleted my 2014 4046h yet but wondering if I should before problems happen
   / Def delete results #2
I deleted the DPF on my 2015 LS 4047 and used a DEF Delete Emulator to bypass the system. No issues after 2 years—better throttle response, no regen downtime, and fewer sensor problems. Just make sure you get a good tuner to handle the ECU adjustments.
   / Def delete results #4
Just got a response Zeotec "they don't have any solutions" for my type of machine. LS3037☹️
40ft 3 Double Door Shipping Container (A45336)
40ft 3 Double Door...
2016 KENWORTH T880 TRI AXLE DUMP TRUCK (A45677)
2016 KENWORTH T880...
Mk Diamond MK-101 Wet Tile Saw (A45336)
Mk Diamond MK-101...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A48561)
Kubota 24in Quick...
2025 Mini Excavator Bucket Attachments (A45336)
2025 Mini...
2022 Peterbilt 337 Single Axle Dump Truck (A45336)
2022 Peterbilt 337...
