Deleting posts
   / Deleting posts #2
Hi Bill,
Can I edit or delete my posts?
"Yes. You can edit or delete your own posts up to 12 hours after they are made. Where the change is substantive, you should mark the post as edited so as to alert viewers to the changed content. For cosmetic changes it's better not to do so. Also, when deleting a post, only a post with no replies will be completely removed from the forum. If your post has any replies to it, the delete function will simply clear the content out of your message, and mark it as deleted.
To edit or delete a post, click on the Edit link, which is located next to the reply link on all of your own posts. "
Additional FAQ's
(What post do you need assistance in deleting?)
TMA (A49461)
TMA (A49461)
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
