Deutz-Allis 5215
   / Deutz-Allis 5215 #1
simenad
Ottawa, Ontario, Canada
Duetz-allis
Anyone know how to mount a second PTO on the 5215 4wd, the manual shows a cover in the front of the rear axel but mine doesn't have it. Maybe only available on 2wd models? Want to mount a bigger hydraulic pump on the second PTO but failing that does anyone know how big a pump I could use if I replace the existing one. The rig is rated at 18 hp but I just had pump and injectors maxed out and I opened up intake and exhaust ports as well as some chamber cleanup, runs great and clean with the extra power so it should run a second pump pretty good. Also any ideas on a charging system mine is not putting out and tried cleaning up the alt but was no help?
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
1240 (A50490)
1240 (A50490)
71063 (A49346)
71063 (A49346)
