Dexter Torflex Axle
   / Dexter Torflex Axle #1
littlediesel
Baldwinsville, New York
L45 TLB, U35, KX71, U17 Excavators, B3030HSDC, F3680, ASV PT40
Do any of you guys know much about the Dexter torsion axle. It is also called the Torflex axle. It does not use a conventional leaf spring design. I am looking at buying a 16' 10K GVWR equipment trailer and it uses the Dexter Torflex axle. I am wondering if the axle is any good.
Thanks,
Jon.
   / Dexter Torflex Axle #2
This is only my opinion but I think they are the best axles out there, I have 2- 7 k axles under this trailer
   / Dexter Torflex Axle #3
My gooseneck horse trailer has them. I like them because if adjusted correctly they make the trailer set closer to the ground. They also (to me ) seem to be more stable (less sway and bounce) at high speeds.
   / Dexter Torflex Axle #4
They are fantastic. The best ride, far smoother than any leaf spring axle.
I'm puzzled though JimBrown, they do not have adjustments. They can be ordered with different angles to the torque arms but they aren't field changeable. I have a Featherlight enclosed 20' trailer that had Torflexs and was built for a low height. I have a steep driveway that made the trailer drag, I ordered new axles that raised the trailer 9 inches, sure wish they could have been adjusted, would have saved me $500 and a days labor to swap them:cool:
They can be remounted with some sort of subframe between them and the trailer frame to alter height but that is a little cheesy. Besides I retained the old axles for some future trailer project, I don't know what yet but I'll think of one:)
   / Dexter Torflex Axle #5
They do give a smoother ride but... each tire is independently sprung and in an extreme case say diagonally going over a curb the entire trailer load could be on ONE tire. Leaf spring axles are setup to toggle one up one down & help distribute the load.
   / Dexter Torflex Axle #6
Torflex are awesome!
I had a 23' Moritz Gooseneck with 2 7k torflex. I hauled my 4150 Kubota with a B106 rotary mower (10,000 lbs +-) all over the southern half of the state, in and out of driveways, fields, dirt roads, construction sites etc... Wore out 2 sets of tires and one set of brakes, never had an issue with the torflex. My Cam Superline tilt trailer with springs rides like crap, I'll NEVER do springs again. Dexter has 8k axles as well, and maybe even a higher rating?
I'm going to sell this cam and have Moritz build me a lowbed with 2 8k torflex.
Everyone mentions that they will bend on rough terrain, but I have never talked to anyone who has actually seen one bent:confused: , whereas my old triaxle trailer with 7k spring axles bent twice.
   / Dexter Torflex Axle #7
BarryinMN - Simple fix- don't go over curbs:D At least not on purpose.....
As for the ride let me give an example- used to have a 20' Wells Cargo, youngest son set an open can of coke on one of the inner fender wells. Drove over 100 miles and opened the door to see the Coke still sitting there on the fender well, unspilled :eek: Try that with a leaf spring trailer;)
   / Dexter Torflex Axle #8
Another great feature about independent suspension is when you have a flat and the other tire will support your load safely,, just take it off and be on your way, these don't have to be chained up to remain off ground in transport like a spring hung axle has to be and did I mention almost no moving parts to wear out. Take a look at how many moving parts on a dual axle spring suspension there is. You will be amazed
   / Dexter Torflex Axle #9
I have 4 trailers with torsion type axles. One enclosed 7k, 14K dump trailer, 14K flat bed and 7k car hauler. I like them. Much smoother ride than axle trailers I have had in the past, especially on the higher rated axles.
   / Dexter Torflex Axle #10
Sticky cans are easy to spot - bigger question is where did he hide the 1/2 eaten sandwich? :D :D
For the trailer based on experience I'd get a deckover instead of the bobcat style. Fenders take a beating & slit the inner sidewall of a tire on occasion.
2018 Maserati Ghibli Sedan (A46684)
2018 Maserati...
(1) Front Tractor Weight (A46502)
(1) Front Tractor...
Trash Combo Trailer (A45336)
Trash Combo...
2105 (A49339)
2105 (A49339)
John Deere 5 Bottom Semi-Attached Plow (A49339)
John Deere 5...
John Deere 4020 Diesel Tractor (A49339)
John Deere 4020...
