DF-354 front wheels...anyone have a spare set?
   / DF-354 front wheels...anyone have a spare set? #1
mpaschetto
Western MA
The previous owner of my tractor swapped the original AG front tires for something
that would do less damage while driving on turf. The original tires and a set of tubes
were included with the tractor, and I'd like to mount them on a second set of rims
for quick swapouts.
- Does anyone have a spare set of used front rims they'd like to sell?
- Can anyone point me in the right direction for a set of new front rims?
TIA,
Mike
   / DF-354 front wheels...anyone have a spare set? #2
extra wheels might be a little scarce. I'm getting a container together, could add a set. What size tires do you have? Is the diameter of the replacment tires the same as the original? If not I would avoid using 4wd until the correct tires are mounted.
   / DF-354 front wheels...anyone have a spare set? #3
Chip is right about not using the 4 wheel drive with those tires on. Good way to tear up an axle or gear box.
Chris
Guys,
I have been careful not to engage the 4WD for the reasons you both mentioned!
- The original equipment tires are 7.50-16, and measure roughly 30" in diameter.
- The replacements look like they're off an F-250 or something, they are 245/75-16 and measure about 28-1/2" diameter.
I can certainly see the potential for damage by operating the tractor in 4WD with those tires on the front....
Chip, I'll get ahold of you by phone today.
Mike
   / DF-354 front wheels...anyone have a spare set? #5
If the rims are the same as the Jinma 354 I have some,maybe Chip can answer that ?
Tommy
Affordable Tractor Sales
   / DF-354 front wheels...anyone have a spare set? #6
I don't have a jinma to compare the bolt pattern. I know the 254 is not the same as jinma, It looks like the DF uses a larger axle, so it might be same as a 354. If someone can measure the bolt circle diameter on a JM354, I can measure one of ours to compare.
I measured up one of my DF-354 front wheels this morning, here are the results:
- Pilot diameter bore: 4.410-4.430" (112MM)
- Bolt circle diameter: 6.00" (152MM)
- Wheel stud diameter: .700" (18MM)
- Wheel width: 5-1/2"
These measurements were taken with a tape measure and a pair of crappy old
calipers, so they may vary somewhat from the theoretical figures....
Mike
   / DF-354 front wheels...anyone have a spare set? #8
My Jinma 354 appears to have a bolt circle diameter of 6 1/4" (maybe a tad more) between lug centers, the inner hole is 4". The lug nuts are 27mm.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
