DF-354 lift arms not parallel....did I break something?
   / DF-354 lift arms not parallel....did I break something? #1
mpaschetto
Western MA
I've got a 2004 DF-354, and this weekend I noticed that the two
lift arms at the rear of the tractor are not level with one another?
Don't the arms share a common splined shaft inside the housing?
If not, is there a way to adjust them to be parallel with each other,
or have I broken something?
TIA,
Mike
   / DF-354 lift arms not parallel....did I break something? #2
Yeah,there is an adjustment on them,one side at least should screw up and down.
   / DF-354 lift arms not parallel....did I break something? #3
If the arms at the top are uneven, it could be assembled wrong or the shaft could have been twisted. the top arms are held to the shaft by splines. you could try removing one and reinstalling to match the other one.
Thanks guys,
Hopefully, the shaft is not twisted!
In any event, I will try to reposition one of the arms this weekend, and see if I can get them parallel with each other...
Mike
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
Zero Turn Mower (A48082)
Zero Turn Mower...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2020 AMCO F42B-3626CS 13ft Pull-Behind Disc Offset Harrow Tiller (A49461)
2020 AMCO...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
