Did my first 50 hrs maintenance ... oh no..!
   / Did my first 50 hrs maintenance ... oh no..! #1
glalonde
Bronze Member
Woodlawn (near Ottawa), Ontario
JD790
Engine oil/filter went fine.
Hydraulic oil.. didn't realize that it would gush out the plug and hit the tire wall instead of dripping in the pan. Seeing this, I tried to hold the pan higher but the weight became too much (my arms were extented). So I had a nice 4'x4' oil swamp on the cement floor. Time for the cat litter.
On the positive side by doing this maintenance, I noticed that the other plug was loose (there's two on each side of the transmission). I could have lost all my oil in the field.
Question: I have filled the oil to the top mark of the dipstick, started the tractor, let it run and checked for leaks (I exercised the loader/3ph too). Then I turned off the tractor, let it cool down and the oil is at the bottom mark of the dipstick. Is this normal ?
   / Did my first 50 hrs maintenance ... oh no..! #2
That would be the norm cause there was probably some air pockets in the system. Add enought oil to get the level half way between the two marks and you should be OK.
2010 John Deere 200 Crumbler Seedbed Finisher (A53117)
2010 John Deere...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
Light Tower (A52377)
Pallet of Lights (A53117)
Pallet of Lights...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
