Diesel Engine Question
   / Diesel Engine Question #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
My new to me 2004 F-250 with ~67000 miles runs very well once it has warmed up. But the engine is very sluggish and underpowered when it is cold. It has the 6.0 liter engine.
I have never owned a diesel truck before and need to know if this is normal or is something wrong? I have a 50-50 warranty on it for 30 days after purchase, so I want to be able to get it fixed if there is a problem.
   / Diesel Engine Question #2
Try here...
PowerStrokeNation : Ford Powerstroke Diesel Forum
Good luck.
   / Diesel Engine Question #3
My '89 Suburban was kind of like that..It certainly ran best and got the best MPG when it was hot...Ambient temperaure also helped...I was a long way from a 2004though.
   / Diesel Engine Question #4
First, change the engine oil. Many of those problems are from sticking injectors from the 15w-40 oil, go to a good10w-30 and see if it changes. If that doesn't help, check the voltage at the FICM (Fuel Injection Control Module) since that is another common problem with the Ford 6.0l diesel...
   / Diesel Engine Question #5
Can't speak specifically of the Powerstroke, but I've read and experienced enough with my Cummins to gain perhaps a tiny bit of insight, although it may very well be wrong. It seems one consensus is to drive your diesel lightly while cold. Once you see the temp gauge start to move, the tolerances apparently begin to close up to where they're supposed to be and you can start to work it harder.
Like I said, this is just something I've gleaned from other forums, so this is how I treat mine... although, I've never experienced the sluggishness you describe. Hopefully some Powerstroke guys can chime in and be of more help than my pointless ramblings. :rolleyes:
Joe
   / Diesel Engine Question #6
If you are planning on keeping it go to a good synthetic oil.
Also what is "cold"? I just about drive at idle until my needle shows about 180.
The dealer claims to have just changed the oil (and what is on the dipstick looks new), I am planning to go to synthetic at the first oil change.
My temperature gauges aren't calibrated, but the transmission temp is starting to move up and the engine coolant is still at the bottom when this happens. I start it at my house and go to the bottom of the driveway which is about 1/2 mile long and about a 10-15% downslope all the way. Next comes a short ~1/8 mile of 7-8% upslope and the truck does not want to go up the hill without really putting my foot into it.
   / Diesel Engine Question #8
You need to let it warm up some. This is common in diesel engines. I run 15W40 in both of my 6.0L Fords with great results. I would not put anything other unless its a 5W40 Synthetic.
As for the sluggishness the injectors are hydraulic driven by oil pressure. Its really a neat design because it will not allow the engine to run without oil pressure but has caused some issues with oil leak by and foaming in the oil. The foaming issue has or should have been by all major oil companies but when I first got my 04 Rotella was awful and all guys would run was Delvac or Dello along with Motorcraft (Ford) oil.
Try letting it warm up a bit and see how this changes things.
Chris
   / Diesel Engine Question #9
My VW Diesels are designed to 'slip' the transmission while cold. Perhaps yours is similar? This lets the engine run more easily when cold. Diesels should be warmed a bit because of the tighter clearances in the engine. Being a hyper-miler, I drive fairly easy anyway. I back into my garage so I don't have to back into the street and start from there. Rather I roll out of my garage and just keep accelerating. It makes a big difference at -30 F. but also works well at +70F.
A big truck (Class 8) will run really, really well after hundreds of miles after everything warms up. I think it is most noticeable after 500 miles.
   / Diesel Engine Question #10
I have a 2005 powerstroke. When I bought it(last year), it had 115000 miles on it. After I had given the guy a check, he told me he had run gas in it, but gotten it fixed. I am pretty sure he had run it for several months after getting it fixed.
It ran 7 miles(It started again, but stopped completely after 100 yards). I had been a bit heavy on the throttle. It turns out the fuel pump is hydraulically driven, and the computer won't let it fire if the pressure doesn't get high enough. I had it towed to a dealer, and after 1600 in labor, they replaced some orings in the fuel pump. It required removing the turbo, and a bunch of other stuff. They didn't replace the pump(400$).
It later turned out that they should have replaced the pump. They made it startable by making the computer skip the pressure fault, and the pump failed(in a parking lot, thank God). They had failed to do a thorough diagnostic the first time around, as the fault was detectable. The cost, again, was >2000.
The symptom for both of these incidents was as you described, rough running at initial startup, and no power until the engine was quite warm. The second set of mechanics claimed that half the pump was not firing. The gasoline contamination may have been the trigger, but these engines have a known issue with the fuel pumps that cause these symptoms.
I used to work around diesels a lot, and never had the -lack of power at initial startup- issue. We always let them warm up, but only for ~30 seconds. Power was never an issue.
Good luck.
Chris
   / Diesel Engine Question #11
By the way, the truck runs nicely now, and has about 150000 miles on it. It is likely I will keep it a long time.
Chris
   / Diesel Engine Question #12
Usually the oil in a Diesel will look new for about five or ten minutes, if that.
   / Diesel Engine Question #13
Chris
Oh, please. If it where anything other than a ford you would be calling it junk.
After a reasonable warmup period (~1-5 minutes) it should be ok. Otherwise, there are a couple things that come to mind ie controller, pump, turbo(s). I would get it checked out. Any way to "borrow" another one for comparison? Used truck test drive ?
   / Diesel Engine Question #14
Ha ha! I can see it now. "Oh, your GM/Dodge diesel is sluggish when cold? Yeah my buddies all have to wait 30 mins for their trucks to warm up but my TWO Ford diesels warm up by towing 50k lb yachts uphill both ways!"
   / Diesel Engine Question #15
Grow up both of you. Starting up any diesel and going strait to work is never a good idea. It does not matter if its in a truck or tractor. I dont do this with my cars but on my diesel stuff I have always let them warm up till the temp gauge starts to move and when I shut down I wait about 30 seconds to let the turbo spool down.
Chris
   / Diesel Engine Question #16
We have a converted ambulance (HazMat rig) at work with 374k
2004 6.0 Powerstroke
While checking last week noticed same thing as you are describing
After start up on high idle if I hit the throttle it was very sluggish to respond. Tried it in drive towing a 10,000 lbs tandem enclosed trailer and very slow
After about 10 minutes of high idle seemed to spool up quick and respond much better.
Don't know the cause
Will ask mechanic at work
   / Diesel Engine Question #17
Chris
That's why I said to wait ~1-5 minutes. Waiting until you have good oil pressure and air (if equipped) should be all that's necessary. On the flip side, if the fire trucks and ambulances waited until they "warm up till the temp gauge starts to move", would you be surprised to see them on the news?
P.S. I'm gonna tell my mom you were mean to me.
   / Diesel Engine Question #18
You got me in trouble :D
   / Diesel Engine Question #20
Which is probably why they keep them plugged in and warm, so they are hot to trot out of the gate.
Caterpillar 906M (A53317)
Caterpillar 906M...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20800 (A56859)
20800 (A56859)
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
