jlgurr
Veteran Member
- Joined
- Oct 21, 2013
- Messages
- 1,024
- Location
- Bostic, NC
- Tractor
- Massey Ferguson GC1705, John Deere STX46
Came across an interesting phenomenon which may simply be the norm for a diesel engine. Will try to explain it and see what the diesel experts think... This happened on a Massey-Ferguson GC1705 but I'm guessing that doesn't matter as it may occur on most if not all SCUT's with a diesel engine.
Was tilling the garden last week and it was pulling hard on the engine. Was running about 2000 RPM or so and thought I'd give her a little more so I nudged the throttle up. No response, so I nudged a little more. No response, so I let off the HST and the engine RPM increased almost immediately, as if a brake had been released.
Being an engineer and curious (sometimes a dangerous combination) I tried to repeat the scenario and get the same results. Voila, it worked. Soooo, I pondered this while puttering around and recalled reading that a diesel engine air intake is always wide open with only the delivered amount of fuel affecting the engine RPM.
With the engine loaded and nearly falling off on RPM, is it plausible that nudging the throttle up did not increase the RPM because the engine could not get any more air; until after the load was relieved by letting off the HST? I don't think what happened is a problem or of any concern, just curious.
Thanks,
Jeff
Thanks,
Jeff
