Diff Lock Operation?
   / Diff Lock Operation? #1
jscusmcvet
Carthage, NC
Satoh Buck
As noted in a post yesterday, I cannot seem to operate the diff lock on a new to me Dahto Buck S470. The pedal to operate the diff lock sits on a set screw or bolt. Seem slike there should be some play there, but there is not. Any help would be appreciated.
John
   / Diff Lock Operation? #2
Do you have the operator's manual?
Yes. When I follow the instructions it does not move at all. I assume the foot lever is supposed to push the piece attaced to engage the diff lock. I cannot get that attached piece to move.
Thanks,
John
   / Diff Lock Operation? #4
How old is the tractor? It could be siezed inside, especially if the diff lock hasn't had much use...
   / Diff Lock Operation? #5
I had similar issues with a diff. lock on a Beaver. The bolt holding the pedal was actually bent down so it was resting on the stop and hence couldn't be engaged. All the problems were on the outside of the gearbox thankfully (even though I ended up taking it completely apart anyway) so don't get discouraged. Just take apart what you can on the outside and try to work the piece going into the gearbox with some WD-40 or similar. I'll bet you'll get it going.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
