Donny, I guess the eyesockets on your arms are CAT 1, and the lift pins on the plow are CAT 2? Is it possible to remove the plow pins, and replace with CAT 1 pins? I know my NH has these quick link ends that can be extended, and after you raise the implement, the ends slide back and self latch themselfs. At least that's how it's suppose to work. I would think that they could be replaced with CAT 1 ends. My TC48 came with CAT 2 link ends, so I bought a set of bushings at Tractor Supply to fit the CAT 1 implements, if I ever get any besides the 3PH Cement mixer, and my Ballast box. Does your DK45S have the links that extend, seems to me it does? That's quite a stout tractor, so CAT 2 shouldn't be out of the question. Can Wallace clue use in on this? Are the Kioti DK45S link ends extendable, and or replaceable? You could away try and swap out the pins on the plow. For another solution, CAT 1 is 3/4", so maybe you could just bolt the plow on with some 3/4" bolts if you have a set that would work. Tractor supply also sells new weldable link ends in both CAT 1, and CAT 2 sizes. I wish we were closer, I'd love to pull that plow, and see if the draft control truely works on the TC48. Drop that plow set into the earth, and seat those piston rings......... /forums/images/graemlins/grin.gif I'd better wind this up, I'm starting to talk myself into putting the orange triangle on, and driving over to your place..... /forums/images/graemlins/smile.gif
