bobm6996
- Joined
 - Aug 10, 2010
- Messages
 - 204
- Location
 - Greenfield, Indiana
- Tractor
 - Mahindra 5010 4WD HST Cab, Mahindra 2615 Gear, Scag Tiger Cat 48", Gravely 42" ZTR, EZ GO Gas Golf Cart
I went to hook up my grapple today and could not get the hoses to connect.  I worked for close to an hour and the only way I finally got it done was disconnect the hydraulic line from the pump on the grapple.  After I did that the male end nozzle point would push in, but was froze solid until I took this action.  I unhooked both connections at the pump and got the hoses from the pump to connect to the hoses coming from the rear remotes.
I went to the rear remotes and unhooked to switch the hose connections from one port to the other and could easily connect one, but the other took several attempts and each time it would get almost in and then I would feel pressure pushing the hose back out.
What is the secret? If it matters this is on a 2014 Mahindra 5010 HST 4 WD.
