Diisel Gator holding prime
   / Diisel Gator holding prime #1
Roy S
2006 Diesel HPX 4X4
I have a 2006 HPX diesel and it will not hold the prime. It runs great but i have to prime it every time i want to start it. Is the check valve in the delivery pump? or elsewhere?
RoyS
   / Diisel Gator holding prime #2
Im not certain about that engine but most of them rely on the valves in the supply pump to stop the flow back to the tank..
Install a clear line from the supply pump to the filter. & run it.. then when full. shut it off & wait till the next day to see if its still full or empty.
If its empty, u know the supply pump is allowing fuel to drain back..
U might be able to take it apart & check the valves for debris.??
Thank you, the clear line is a good suggestion.
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
Loader Bucket (A53421)
