Dimension or picture from 425 owner
   / Dimension or picture from 425 owner #1
bullitt
Pittsburgh PA
pt422
Hello everybody,
I am preparing to put a Kohler 27 hp engine into my 422. The deisel option ended up being very expensive ($5k+) and is therefore beyond my budget and not very cost effective when compared to the 1430.
The Kohler drawings are less than complete. If I could get some approximate dimensions, it would help check my work before I have the 422 apart and discover a dimensional boo-boo.
As a check of my dimensions, the following off a 425 would be helpful:
1. A picture of the front lovejoy coupling between the screen over the flywheel and the vertical portion of the engine cradle.
2. The approximate dimension between the screen and the vertical portion of the engine cradle.
3. Or the dimenstion between the vertical portion of the engine cradle and the vertical face of the forward part of the lovejoy coupling where it goes from a small diameter to a large diameter. This is a critical dimension, but I suspect this may not be visible as it looks like it will be behind the screen.
The Robin engine is destined to become a 10 or 12kW generator.
Thanks in Advance
bullitt
   / Dimension or picture from 425 owner #2
if you saw my post about the new 425 you may decide to go an other direction,the wheel motors may give you the power you are looking for? i also did some research in to a smaller wheel tire combination with a 21" high tire vs.23 high tire. now that will give very substantial increase in power.i live in blairsville pa. if you need help with any thing.
2015 Kubota MX5200F Front Loader Tractor (A49346)
2015 Kubota...
New Tractor Seat (A47371)
New Tractor Seat...
KC QT-SG-S76-V3 76in Skeleton Grapple Single Cylinder Skid Steer Attachment (A46683)
KC QT-SG-S76-V3...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2016 Ford F-150...
2018 Chevrolet Impala Sedan (A48082)
2018 Chevrolet...
More info coming soon! (A48082)
More info coming...
