Direct drive chipper question
   / Direct drive chipper question #1
worthb
Bronze Member
I am about to buy a chipper and wanted some input first. I am looking at the Value Leader 4" chipper. It looks to be a close copy to the Wallenstein BX42. It is a direct drive chipper and I am concerned about the shock to the PTO driveline. I know there is a shear bolt. Does anyone have any comments or problems with direct drive vs belt drive? Any help is appreciated.
   / Direct drive chipper question #2
I've had two chippers - Wallenstein BX42S and now the BX62S. I used the 42 on my 28 hp Ford 1700 and now the 62 on my Kubota M6040. Both have shear bolts. I never had a moments problem with either and have never sheared a safety bolt on either. About 99% of my chipping is Ponderosa pine. I will occasionally chip some of my apple trees and I chipped about six locust trees for the neighbor. The locust had dried about 2-3 years and were as hard as a rock. It had no trouble chipping them either. I'm sure the shock loading to the drive line is part of the total engineering package when they design the chipper. I have no experience with a belt drive chipper nor any knowledge of Value Line chippers.
Just be sure to use the pto drive line recommended by the chipper manufacturer.
Thank you for the input. I was wondering how vulnerable the shear bolt is under normal use.
   / Direct drive chipper question #4
I have a BX62 and have never broken a shear bolt either. I have stalled the tracker, though. The BX62 has a big mouth and if you feed it too much it will bog down my DX45 to the point of stalling it.
   / Direct drive chipper question #5
I've sheared a couple of bolts in my BX62, and also stopped/jammed the chipper with too heavy a load of maple. I think the momentum of the flywheel absorbs most of the shock loading; when it is excessive, the shear bolt will go.
   / Direct drive chipper question #6
You have to realize that pine is probably one of the softer woods to chip - along with alder, birch, aspen and the like. The Wally '42 would take stuff up to 4" in diameter and I could never bog it down with just pine trees. Feeding dry hardwoods could be another matter. Like Stonehaller said - if you run the chipper at the recommended pto rpm and feed one tree at a time - I really doubt there will be a problem. The mass of the rotating flywheel will absorb the majority of any shock loading.
I did have a problem with the '42 - I feed the pine trees hole (limbs & all) and I would get the pine sap, from green needles, causing plugging in the discharge chute - nothing to do with shock loading. I thin my stands and annually chip 750-900 trees. Now I thin & stack in the spring and chip the following year plus the '62 has a higher air flow and larger discharge chute.
   / Direct drive chipper question #7
I suspect you should compare the weight of the flywheels to judge the shock that two equal pieces of wood would put on the drivelines.
That's a good point that I didn't think about. The Value Leader chipper flywheel is listed at 115 lbs. The Wally is 75 lbs for the BX42. Pine is the only wood that scares me. I guess I could run it through mixed between some hardwood to help clear the sap.
I don't want to save $ on a chipper only to tear up my tractor.
   / Direct drive chipper question #9
I really wouldn't be worried about the pine trees unless you run a lot - 50 to 100 - thru in a row and if they are green and have the limbs & needles attached. On the '42 it would take that number to get enough pitch build-up in the chipper chamber/chute before the thing started plugging. I cleaned the chamber/chute by washing down with turpentine and it was ready to go again. OR I'd alternate some dry pines in with the green stuff.
Otherwise - I don't see near the system shock on a chipper that you would see on a rototiller.
Thanks to all of you for your input. You have put my mind at ease.
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
Rooster Artwork (A55758)
Rooster Artwork...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2022 Horizon (A55973)
296385 (A57192)
296385 (A57192)
