Dirt Scoop Users - Don’t Do What I Did!
   / Dirt Scoop Users - Don’t Do What I Did! #1
MikeFLA
Central Florida
Kubota B7500
I recently purchased a dirt scoop for use with my B7500. I have been very pleased with it’s construction and usefulness. Initially I used it with the blade facing rear; so that I could back up into a dirt pile.
I thought I would try it the other way, so I unhooked it and turned it around. Blade facing forward. After connecting it, I raised the 3 pt. Hitch, put it in gear and took off.
Immediately an incredible vibration and noise that shook the entire tractor occurred. I don’t think I moved 10 feet. I jumped off the tractor fearing the worst. I don’t know what I was thinking but I knew it wasn’t good.
Upon inspection I discovered the problem. When I raised the 3 pt. hitch, both sides of the blade of the dirt scoop came in contact with my R-4’s causing the problem. Fortunately I found relatively minor tire damage but it could have been a whole lot worse. That blade is sharp and could have punctured the tires or severely damaged the bars.
Please learn from my mistake. Don’t let this happen to you!
   / Dirt Scoop Users - Don’t Do What I Did! #2
Ouch/w3tcompact/icons/crazy.gif! You are fortunate nothing worse happened. Think what it would've been like if you had AG tires /w3tcompact/icons/shocked.gif!! Glad to hear nothing serious happened. But it is a heck of way to clean the mud off of your R4's /w3tcompact/icons/sad.gif.
   / Dirt Scoop Users - Don’t Do What I Did! #3
I knew the scoop could be reversed, and I think it might be a lot easier to fill, but I keep wondering how the heck I'd empty it? The trip would be in the back. Half the time I have to lean over and nudge it a little to tilt. I'm hoping I won't need to do that so much now that I put the hyd. top-link on.
Mark,
I make a habit of lowering the scoop first to take the pressure off the mechanism, pull the rope and lift the 3pt hitch. Dumps every time.
   / Dirt Scoop Users - Don’t Do What I Did! #5
I do it that way also, but it most definately does not dump every time for me. I think the pins are almost dead center, so it just hangs there, balanced perfectly /w3tcompact/icons/hmm.gif.
By extending the top link I'll either get the stuff to slide enough to make the scoop function, or maybe the dirt'll just go without the "dump" of the scoop /w3tcompact/icons/smile.gif.
   / Dirt Scoop Users - Don’t Do What I Did! #6
I was taught to pull a scoop forward for grading, push it in reverse for scooping. The trip latch is an issue for all the models I've used over the years, large and small, especially when in the pull/grading position. I was surprised when I read about the clearance on the 7500. I have a "baby" 5 1/2 bushel scoop that clears the tires on my garden tractor in all positions. You must be dragging a good sized scoop.
   / Dirt Scoop Users - Don’t Do What I Did! #7
Re: Dirt Scoop Users - Don?t Do What I Did!
Mike, I've posted this before but it may be worth repeating. I was using my dirt scoop about three years ago and had an accident. I tied a piece of rope to the trip lever but was too lazy to go get a knife to cut off the excess. I was driving across my lawn and had the loose end of the rope coiled up in my hand. Turns out that a few feet of rope was dangling down as I drove. The rear tire on the left drove over the rope and pulled my hand into the fender eventually breaking the rope. I broke all four fingers in several places and had to have the ring finger reattached at the knuckle just behind the nail. Believe it or not, I still use the dirt scoop. Only now, I use a very short piece of rope and I never hold it while driving.
Jerry
   / Dirt Scoop Users - Don’t Do What I Did! #8
I've used a rear blade before, and know what a box scraper is; but danged if i know what a "scoop" is. Does anyone have a pic they could post to help learn me what a scoop looks like.
Thanks,
Moon
   / Dirt Scoop Users - Don’t Do What I Did! #9
here ya' go
   / Dirt Scoop Users - Don’t Do What I Did! #10
Thanks Pitbullmidwest!!!
never seen one until now, but at least i now know what the heck it is.
Thanks,
Moon
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
