Disassemble drive shaft
   / Disassemble drive shaft #1
LGP
I have a S630D Satoh and I need to take the rear drive shaft, that goes to the front axle, out of the casing. Any Suggestions?
   / Disassemble drive shaft #2
I assume you are talking about the propeller shaft running from the transmission to the front axle. Remove the covers by removing the four bolts clamping them together. Remove the four bolts at the rear flange and pull the drive shaft rearward off the splines of the front differential input assembly. You may also have to remove the bracket below the front of the shaft. Need more help? call 800-609-5110. Bill (satohparts.com)
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
