Disc harrow HP requirements.
   / Disc harrow HP requirements. #1
mjncad
Super Member
In the civilized First World
A couple
Is there a rule of thumb for disc harrow HP requirements? For example, 5hp per 1-foot of harrow width?
   / Disc harrow HP requirements. #2
I would think that it would depend on how heavy the disc is. We had a heavy one when I was farming that was only 6ft. Many I see today the same size, would take a lot less hp because they are so lite.
   / Disc harrow HP requirements. #3
Depends on several variables: weight of the disc, depth of blade penetration, soil type, soil moisture. I use a heavy 6.5 ft wide offset disc and pull it with my 2008 Mahindra 5525 (55 hp engine, loaded rear tires, about 6500 lb tractor weight). YOu need to pull a disc at 5-6 mph to get it to work effectively. I have plenty of hp in dry soil. If the soil is wet, then the disc digs deeper and loss of traction is a problem. So my guess is you'll need 5-10 engine hp to operate a disc like this.
   / Disc harrow HP requirements. #4
Clarification: 5-10 engine hp PER FOOT of disc
   / Disc harrow HP requirements. #5
Too many variables to really give you a good accurate answer. From my own personal experience I would say 1/3 of the pulling tractors weight would be maximum weight that you could pull. Width will not matter.
A disk that is 6' wide and weighs 2000lbs will pull about the same a a disk that is 8' wide and weighs the same 2000lbs. Everything on the wider disk is smaller and lighter weight per foot of width.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
New/Unused Quick Attach Auger with Three Bits (A54865)
New/Unused Quick...
2017 Mitsubishi Mirage G4 Sedan (A55758)
2017 Mitsubishi...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
