Disposal of oil
   / Disposal of oil #22
Some people add it to their heating oil,I'm told.
Apparently win/win.
   / Disposal of oil #23
Apparently win/win.
I wouldn't think that would be a good idea...the gunk from the motor oil would likely clog your filter up pretty quickly. Not sure what the difference is between a "normal" furnace and a waste-oil heater. Any plans for a DIY one generally seemed to use a drip system instead of a nozzle.
Many years ago I tried using it for bar oil in my chainsaw. Bad idea. The aforementioned gunk did a good job clogging up all the chain lube passage ways. Real PITA cleaning it out. All that to save $5 on a gallon of bar oil. :duh:
   / Disposal of oil #24
I think the reality of people doing it,kind of beats presumptions.
On another note, oil good enough for a 30k vehicle lubricant should 'suffice ' for simple burning.
   / Disposal of oil #25
Our local muffler/welding shop burns it to heat their shop. The filters & oily rags, I burn in my shop wood stove.
   / Disposal of oil #26
Never paid much attention to burning oil until i found out the place I am moving to has an oil furnace for the shop. Does all this synthetic oil and hydraulic fluid burn like Dino oil?
   / Disposal of oil #27
I got a used 275 gallon plastic chemical tote and put my used oil in it. I don't put any antifreeze, etc in there but I do put used motor oil, transmission fluid, hydraulic fluid, etc. When full I call the local oil recycler and they come pump it out for free. They told me if I had over 1000 gallons a year or something like that they would actually pay me for the used oil but I don't have that kind of volume so they just take it for free. Depending on how busy we are I have to get it pumped once or twice a year but we have lots of things with engines and a couple neighbors come by and dump their oil in there as well as it is more convenient for them than running to town.
   / Disposal of oil #28
I was going to do that with an old heating oil tank, luckily I called the place that picks up our oil at work before I did. 275 gallon disposal was going to cost $175! Work gets paid for their waste oil, but home owner doesn't. So, to the curb it goes. Glad it worked out so well for you though!
Hose Reel (A53424)
Hose Reel (A53424)
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
