DIY electric install?
   / DIY electric install? #1
crowbar032
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
Not exactly a build it yourself post, but just wondering if any non-electricians have installed their own electric. I had a pole barn (42x56) build that I want to put electricity in. I will be coming from another box in another building so I won't need an inspector or to tie onto the utility pole. I'll be using direct bury cable (I'm still putting it in conduit) in a trench. I'll have to rent a trencher as I want to go at least a ft deep. To match the other boxes and breakers I want a 200 amp Cutler Hammer box. I'm not planning on anything fancy, just 110 volt outlets and some shop lights. I do want one 220 outlet so I can run a welder in the future. There is a double breaker slot open in the box I'll be coming off of so I can have one 220 outlet.
I'm still debating on the 4' or 8' flourescent lights. I saw some at Lowes that said there was no warm up time down to -35 degrees. I hate turning on a switch then having to wait for the light to warm up before you can see.
   / DIY electric install? #2
I believe you are mistaken thinking that you don't need to get permits and inspections. Code out here for UF is 20" deep with mylar tape so it can be found. I did almost the exact same project for a 12x20 shed I built and had to pull permits to get the 220 from a sub-panel in my garage to the shed. I didn't use UF, but decided on running conduit instead. 4 years later, we put in a pool and the spot to put the pumps and heater were there at the side of the shed. The pool company had to have the install inspected and had I not pulled permits and gotten inspections, I would have probably been facing a pretty hefty fine.
   / DIY electric install? #3
Yes, I've done the electrical work in my own houses but a permit and inspections are required.
   / DIY electric install? #4
I ran power to my barn 85' from the house.
From your house you need a double breaker. It must be sized to protect the size wire you run. You may need adapter lugs to tie the wire into your neutral/ground bar in your house.
I used conduit to, but a foot deep is not deep enough. Go deeper
A 200a box in your barn seems overkill. What size breaker do you plan at the house for this sub panel? There is no need for a main breaker in a sub panel, but it's nice to be able to shut the whole panel down to work on it vs going back to house to shut it off.
If you already have the 200a panel use it. How many spaces does it have? You will need two spaces for a 240v circuit. I like to put lights and outlets on separate circuits. That way if you overload an outlet and trip a breaker you will not lose your lights too.
Do not ground/bond the neutral bar in the sub panel.
Put ground rods in at the sub panel.
Start each outlet string with a GFCI outlet.
Use 20a breakers for outlets. Do not use the cheap $.49 outlets. Use at least commercial grade. Do not use "back wire" that you just push the wire into the back of the outlet (trouble down the road). Back wire that requires tightening a screw is fine. Use 12-2/ground wire.
Use 15a breakers for the lights and 14-2/ground wire (cheaper than 12-2/grd) Limit your light load to 1440watts per breaker.
I would use 4' T8 lights. I hear 8' T12 are being phased out.
   / DIY electric install? #5
your getting yourself into trouble. there is a good amount of codes / regulations. that could bite ya quickly. and/or if not done right could be a electric shock to fire hazard, to a bad ground that could cause a bunch of other troubles.
call up some electricians and see if you can get some free bids done. tell them flat out, what you want to do, and can do yourself. also let ya know if the other box ya coming off of can even allow things. ya you might have an open slot. but amount of amps sending to other shed. could overload the current box you have. most will work with you. some times, it can be just flat out pain in rear to work like that. vs who ever coming in and doing it themselves. (less blah blah blah between you and them) and at times can make there length of time of actually doing things quicker. sometimes not pending on your skills and knowledge.
normally an electrician will have the proper tools to make a job go quicker and easier. (driven ground rods), special wire tools to deal with insulation on them, already have some lubrication for wire pulling etc...
with above said, i have ran knew 240 volt out to sheds, and redone house and sheds electricity. it is all pretty easy. but the knowledge and keeping to code can be rather tricky and pain at times. but at AMPs you are talking about... get a local electrician involved. so they know the local codes. and can point ya in correct direction to take.
Technically, yes I should have a permit. And I would do it if the whole permit process wasn't a joke and a pure money grab by the county. The box I want to come out of was permitted, inspected, and passed before the electric company would connect it to the pole. Running out of that already permitted and inspected box should not need another permit. The only reason they want a permit is so they can jack up the property taxes because the barn has electric. I'm being stubborn on principle and politics.
The only thing running on the current box are some shop lights and an air compressor.
I do have access to an electician for advice. However, I was hoping to do most of this myself. And he's not much in the motivation department, but he's good when he's willing.
   / DIY electric install? #7
First off- a quick call to your local town to see if a permit is needed should be made. second- 1 foot deep for buried power? you are just asking yourself for alot of problems. If you were not around and someone is tilling or breaking up soil and hit that line .... I shudder to think that they might not make it out alive.
   / DIY electric install? #8
I think it depends on the state and county u are in. Mine doesn't (or at least didn't used to) require a permit. If worried would check with a electric supply and see what they say.
   / DIY electric install? #9
It is true that most regs are local and vary. As far as the actual work it is another job that is easy to do. Get a book that gives the wire size vs breaker amps and what type of wire for different applications and ground faults where needed. Follow the codes and no problem, do not cheat. Calling the government would be a mistake unless you are going to follow through with the permits and licenses and inspections, once they get wind of a project they will descend on you like a pack of wolfs if they suspect that you have done anything.
   / DIY electric install? #10
I've done a lot of electrical work. I'm not a professional but I have relatives who are. If you do it yourself, do it right. Learn about the code requirements. Use the right size and type of wire and breakers. Fasten down the wire where required. Keep in mind that doing it right takes a lot longer than you would expect if you don't do this all the time. When I have needed a major amount of work done or work with wire larger than #10, I hire a pro. It's a bargain when the job is complicated.
   / DIY electric install? #11
DIT isn't the problem, knowing how to do it safely and real close to code is.
Having your buddy tell you how it should be done is almost as good as having him help you.
There are a lot of things with electric that if done up front will save you a lot of trouble later.
I pulled a "Homeowners Permit" for my electric and plumbing a year ago last July when I bought a new Manufactured Home. I trenched it before the home was placed and I went 24-30" deep. I had to do the permits.
I ran 4-0 aluminum 60' through PVC conduit from the pole to the home for 200amp service.
I sweated pulling the wire but after sucking a rope through with a shop vac and taping it to the wire it took 5 minutes to pull with a friend pushing at the same time!!
There is so much info on the net that you can probably find videos showing the how to's.
And if you can use aluminum for the main it will be less than half the cost of copper. Of course only copper for the circuits!
   / DIY electric install? #12
The only problem you can get into by doing the work is if theres a fire, or other problem. It doesnt even have to be in the building your working in. If an insurance company comes to your property to investigate a claim, and can find work done (electric, plumbing, whatever) WITHOUT any permits, they can .... and often do.... deny any claims for damage.
its a sad fact, but ive seen it happen in Calif, Oregon and Idaho. im sure it happens everywhere else also.
Here in Idaho a shop/barn permit only costs approx $75 ... so why risk losing insurance over $75 :confused:
also, FYI... direct burial UF cable needs 24 coverage (18" if in pipe).
2/2/4 urd direct bury aluminum capable of carrying 100 amps is only $1.22 / foot (plus 0.25 for a #6 ground wire). Why wire a shop as large as yours with a small circuit, when for a few bucks more you can get 100 amps ( or 50 amps) .
   / DIY electric install? #13
You've said a few things wrong already, so while installing electric can be a diy job, I'm not sure you are up to the task. We all love to save money, and most of us enjoy sticking it to the govt, but - if you mess up electical, you set up a timebomb waiting to hurt someomne could be a decade from now.
--->Paul
   / DIY electric install? #14
The only reason they want a permit is so they can jack up the property taxes because the barn has electric. I'm being stubborn on principle and politics.... <snip>
Is this property going to ever be sold? So you are going to subject them to whatever is done right or wrong? What happens if somebody gets killed due to you not doing it correctly?
I *used* to do electrical work, and do my own, and I am *100%* in agreement with inspections, to protect me from being sued by someone in the future over alleged workmanship flaws. I *want* an inspection report filed with the county so that I have a leg to stand on if something goes wrong in the future.
   / DIY electric install? #15
Crowbar these guys are trying to protect you from what you don't know, and I agree with them completely. Before I got training and professional experience working with electricity, I knew just enough to be dangerous. And the DIY work I did at that time, I now know, WAS dangerous and incorrect because of my ignorance and inexperience. Luckily I didn't kill anyone or burn anything down. Don't count on luck when working with this stuff. Best regards.
After reading the comments, I'm second guessing myself. I think I need to do some more planning/education before I attempt this. Thanks for the input.
   / DIY electric install? #17
there is a good book called "wiring simplified", and it revised ever code cycle, there are two versions of it, a short and a long version, "Practical Electrical Wiring: Residential, Farm, Commercial & Industrial: Based on the 2011 National Electrical Code" (actually I suggest both, the short just hits the high points the long version goes in to more detail,
long version, Practical Electrical Wiring: Residential,Farm,Commercial & Industrial: Based on the 2011 National Electrical Code: Herbert P. Richter,Frederic P. Hartwell: 9780971977969: Amazon.com: Books
short version, Wiring Simplified: Based on the 2011 National Electrical Code: H. P. Richter,W. C. Schwan,F. P. Hartwell: 9780971977976: Amazon.com: Books
it will guide one through the process very well,
as far as permits and inspections, (in most areas it is state law to do this),
but so not cut corners on wire size, use the proper wire type and sized for the amperage of the breakers you choose,
   / DIY electric install? #18
--->Paul
It's not rocket science. Doing the wiring is the easy part, but sitting at the library and going through the NEC to figure out burial depth and wire size is the hard part. Good luck.
   / DIY electric install? #20
I did my own here, including putting in the power pole, and the full 200 amp for the house, 100 amp to the shop, and 60 amp to the pump house. Not that hard, but I pulled a permit, only 50-75 bucks years ago. Passed the inspection at 100 percent, and even taught the inspector about the always live sub panel going to the pump house, for the "fire pump". But as others have said, a fire, and no permit, and inspection, may void your insurance, and that's not worth the risk in my book.
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2010 CATERPILLAR 303.5C CR EXCAVATOR (A60429)
2010 CATERPILLAR...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2011 Freightliner Cascadia 113 S/A Day Cab Truck Tractor (A59230)
2011 Freightliner...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
