davesisk
Platinum Member
Hey folks:
Does anyone know of supplies and processes to just foam-fill your tires yourself? As I understand, two different liquid chemicals are injected under pressure, and when they mix they form the foam. I'd assume they are injected through the valve stem.
I'm thinking two of the small portable air tanks would probably do the trick. Take the valve off each tank and partially fill it with the liquid component, put the valve back on, pressurize the air tanks with an air compressor, then with the valve side down, inject into the tire through the valve stem. Only trick would be insuring that you got the mix right.
Thoughts? Surely this is do-able.
I've got a quote locally to fill both rear tires (315's) with foam for about $140 each, which doesn't seem too bad, but that's still quite a bit of money.
Thanks,
Dave
Thanks,
Dave
