DIY valve adjustment
   / DIY valve adjustment #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
Anybody got a good DIY on a valve adjustment on a Kubota 3 cylinder. I have a 21.5 hp diesel in my Hustler Zero turn that has a lot of clatter and I have never adjusted the valves.
   / DIY valve adjustment #2
What do you mean "good DIY on a valve adjustment"?
I pretty much just removed a few hoses in the way, removed the glow plugs to make turning the engine easy, and removed the valve cover. It had a rubber gasket which my manual said was re-usable, but I bought a new one anyhow.
Took my measurements and made my adjustments on each valve where tehy were suppose to be measured.
Deano
A DIY is a walk-through the process.
Thanks for the link Randall
   / DIY valve adjustment #6
When (HR wise) is it recommended to check or adjust the valves on these engines?
   / DIY valve adjustment #7
I would go by the recommendations of the manufacturer.
On the D950 in my Hustler it is every 800 hours
   / DIY valve adjustment #9
Thank you for mentioning that you remove the glow plugs to relieve the compression. I know how to do valve adjustments, but I never did a diesel and no spark plugs to take out. I couldn't find them :)
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A48081)
2008 Ford F-250...
Unused Delta Crash...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
Mitsubishi FGC20K Forklift (A50860)
Mitsubishi FGC20K...
2004 Hyundai Santa Fe SUV (A48082)
2004 Hyundai Santa...
Super Material Lift MH1000 (A51039)
Super Material...
