jbain
I've been working on this for some time and feel that the problem is a relief valve.
There is a relief valve in the hydraulic block but is there another?
I have replaced the hydraulic pump so not the problem.
I don't have any quick couplers below the deck that could be coming off.
I don't have a loose hose and no leaks.
The symptoms are no lifting power on the 3 point or FEL. Hydraulic pressure 1000 psig.
Replaced filter and fluid.
Problem occurred in the field brush hogging went to lift the FEL to clear a fence and really slow lift.
Thanks for any help.
