DK35 oil leak[frown]
   / DK35 oil leak[frown] #1
jb112454
Prague OK
2001 Kioti DK35
well i finally found a problem NOT! you big 3 out there thought here it is kioti has a problem. well sort of a problem but not really. the dk35 has a mid pto that has a cover to keep things form getting wrapped around it when it's not being used. this cover is the problem. while doing some trenching a root stabbed directly into the end of the cover which is open. a piece of the root pushed through the seal to shaft area and the trans fluid started to drip out. you should have seen how fast i crawled under that tractor to see how big the hole i had busted in my new tractor. fortunatly it was as simple as a piece of wood stuck in the seal. it didn't damage the seal and i even engaged the mid pto to see if any more fluid would come out and none did. the fix to this problem is to weld a washer on the end of the cover so it does not have that sharp edge to core those roots.
2018 PJ 40T/A GOOSENECK TRAILER (A50854)
2018 PJ 40T/A...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
